Samsung S22E450DW 22" 1680x1050 5ms VGA DVI DisplayPort USB LED Monitor
Key features
  • 22" screen provides excellent visibility and legibility
  • Built from up to 30% recycled plastic, with less than 0.005W off-mode power consumption
  • VESA mount compatibility, VGA, DVI and DisplayPort connections, and speaker bar compatibility
Product codes
chevron icon
chevron icon
The SE450 Series provides an environmentally friendly, user friendly and budget friendly yet high quality desktop monitor solution for your business. Features include a simple and easy to use design, fully adjustable stand, matte black bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
chevron icon
Product Description Samsung S22E450DW - SE450 Series - LED monitor - 22"
Device Type LED-backlit LCD monitor - 22"
Energy Class Class G
Power Consumption (On mode) 23 W
Features USB Hub
Panel Type TN
Aspect Ratio 16:10
Native Resolution 1680 x 1050 at 60 Hz
Pixel Pitch 0.282 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms
Colour Support 16.7 million colours
Colour Gamut 72% (NTSC 1976)
Input Connectors DVI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Voltage AC 120/230 V
Colour Black
Dimensions (WxDxH) - with stand 50.24 cm x 21 cm x 38.75 cm
Weight 5.03 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards C-Tick, EN55022, SASO, EN55024, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, UL60950-1, GB 4943-2011, GB 17625.1-2012
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
