The Samsung LED Business Monitor SA650 has been designed to enhance work conditions and efficiency. Featuring Front Tactile Buttons, the SA650 minimizes costly errors found with high usage, which is a common problem with touch type button monitors. Furthermore, with its smarter design, users can still access these buttons when wall mounted, which can be an issue when monitors feature side panel buttons. Adding to the visual experience, the SA650 features a Narrow Matt Bezel. This reduces distraction around display area and delivers an experience that is immersive and engaging.
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SA650 is the perfect choice. From physically moving the monitor with the carrying handle to quickly installing, the SA650 is ready to deliver an efficient and clean work space. The SA650 is also equipped and prepared for you as a VESA Wall mount, providing a multi-screen or wall mounted monitor. Optimizing your office space is now easily achieved with the Samsung LED Business Monitor SA650.
The Samsung LED Business Monitor SA650 has been designed to help boost work efficiency, delivering a tailored experience with its choice of viewer settings. The height-adjustable stand ensures that the screen can always be set at the optimal eye level, which enhances the visual experience while also helping maintain the viewer's body posture. Other features include the tilt and pivot capabilities, which not only increase comfort levels but also introduce new ways of working. The SA650 Monitor can rotate 90 degrees, allowing for more appropriate view depending on the work. So, now you can take convenience and efficiency to amazing heights with the Samsung LED Business Monitor SA650.
Product Description | Samsung S22E650D - SE650 Series - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" | Panel Type | Plane to Line Switching (PLS) | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 72% (NTSC 1976) | Input Connectors | DVI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V | Colour | Black | Dimensions (WxDxH) - with stand | 50.43 cm x 21 cm x 35.44 cm | Weight | 4.87 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus |
Colour | Black |
Dimensions (WxDxH) | 50.43 cm x 21 cm x 35.44 cm - with stand |
Weight | 4.87 kg |
Connectivity | |
Interfaces | VGA , DVI , DisplayPort |
Mechanical | |
Tilt Angle | -3/+25 |
Swivel Angle | 90 |
Rotation Angle | -1/+95 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x DVI cable , 1 x VGA cable |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption (Typical) | 22 Watt |
Power Consumption Sleep | 0.3 Watt |
Power Consumption (Off Mode) | 0.005 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 50.43 cm - depth: 21 cm - height: 35.44 cm - weight: 4.87 kg , Without stand - width: 50.43 cm - depth: 5.54 cm - height: 30.19 cm - weight: 3.27 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
