Samsung S24E200BL 23.6" 1920x1080 5ms VGA DVI LED Monitor
Key features
  • Built from up to 30% recycled plastic
  • Less than 0.1W off-mode power consumption
  • VESA mount compatibility, VGA and DVI connections, and speaker bar compatibility
Product codes
chevron icon
chevron icon
The SE200 Series provides an environmentally friendly, user friendly and budget friendly desktop monitor solution for your business. A simple and easy to use design, a matte black bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel make this 23.6" monitor a perfect value for everyday tasks.
chevron icon
Product Description Samsung S24E200BL - SE200 Series - LED monitor - Full HD (1080p) - 23.6"
Device Type LED-backlit LCD monitor - 23.6"
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.2715 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms
Colour Support 16.7 million colours
Colour Gamut 72% (NTSC 1976)
Input Connectors DVI, VGA
Display Position Adjustments Tilt
Voltage AC 120/230 V
Colour Black
Dimensions (WxDxH) - with stand 55.46 cm x 18.5 cm x 41.27 cm
Weight 4.06 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV, C-Tick, EN55022, SASO, EN55024, CISPR 22, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, UL60950-1, GB 4943-2011, GB 17625.1-2012, IEC60950-1
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
