Samsung's SE650 eco-friendly LCD monitor delivers an unmatched user experience, while maximizing energy savings and sustainable design for reduced environmental impact. Using the monitor's Eco-power off mode the SE650 offers 0.00 W power consumption when in off mode. This is significantly lower than the 0.3 W to 0.5 W experienced with the average monitor, leading to significant savings in energy, resource and cost over time. Along with superior power consumption, the monitor is designed with a recycled plastic and PVC-free body. The recycled plastic and PVC-free body offer health and environmental benefits throughout the monitor's lifecycle, beginning with production, where it reduces the emission of harmful pollutants. During use, the monitor keeps PVC-related toxins out of the user's home, school and office. Finally, when correctly disposed, the monitor prevents PVC from leaking into soil, crops and water supplies.
Product Description | Samsung S24E650XW - SE650 Series - LED monitor - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class G | Power Consumption (On mode) | 30 W | Features | USB Hub | Panel Type | Plane to Line Switching (PLS) | Aspect Ratio | 16:10 | Native Resolution | 1920 x 1200 | Pixel Pitch | 0.269 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 4 ms | Colour Support | 16.7 million colours | Input Connectors | DVI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Colour | Matte black | Dimensions (WxDxH) - with stand | 55.48 cm x 22.4 cm x 51.73 cm | Weight | 5.8 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | TUV GS, DDC-2B, ISO 9241-307, EMI | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Built-in Devices | USB Hub |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | MagicBright, power off timer, MagicRotation, HDCP, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving |
Dimensions (WxDxH) | 55.48 cm x 22.4 cm x 51.73 cm - with stand |
Weight | 5.8 kg |
Audio | |
Type | Speakers |
Connectivity | |
Interfaces | VGA , DVI , DisplayPort , Audio line-in , 2 x USB |
Mechanical | |
Tilt Angle | -3/+25 |
Swivel Angle | 90 |
Rotation Angle | -1/+95 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | PVC free |
Cables Included | 1 x VGA cable |
Power | |
Power Consumption SDR (On mode) | 30 kWh/1000h |
Power Consumption (Typical) | 30 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.005 Watt |
Software / System Requirements | |
OS Required | Windows 8.1 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 55.48 cm - depth: 22.4 cm - height: 51.73 cm - weight: 5.8 kg , Without stand - width: 55.48 cm - depth: 5.51 cm - height: 35.94 cm |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
