The SE450 series provides an environmentally friendly, user friendly and budget friendly yet high quality desktop monitor solution for your business. Features include a simple and easy to use design, fully adjustable stand, matte black bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
Product Description | Samsung S27E450B - SE450 Series - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class G | Power Consumption (On mode) | 34 W | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms | Colour Support | 16.7 million colours | Colour Gamut | 72% (CIE 1976) | Input Connectors | DVI, VGA | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V | Colour | Black | Dimensions (WxDxH) - with stand | 63.9 cm x 22.4 cm x 39.78 cm | Weight | 6.7 kg |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Panel Type | TN |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Features | MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus |
Colour | Black |
Dimensions (WxDxH) | 63.9 cm x 22.4 cm x 39.78 cm - with stand |
Weight | 6.7 kg |
Connectivity | |
Interfaces | VGA , DVI |
Mechanical | |
Tilt Angle | -4/+25 |
Swivel Angle | 90 |
Rotation Angle | -1/+95 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x VGA cable |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption SDR (On mode) | 34 kWh/1000h |
Power Consumption (Typical) | 38 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.005 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 63.9 cm - depth: 22.4 cm - height: 39.78 cm - weight: 6.7 kg , Without stand - width: 63.9 cm - depth: 5.76 cm - height: 37.81 cm - weight: 5 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
