We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
So many ways to connect with HDMI, Display port, VGA and USB. A full line up for ports brings you the complete connectivity you need in today's working environment.
Protected eyes stay focused through the whole shift. Advanced eye comfort technology reduces eye strain for heightened concentration and greater productivity. Flicker Free technology continuously removes tiring and irritating screen flicker, while Eye Saver Mode minimizes blue light emissions.
The height-adjustable monitor swivels, tilts, and pivots for you to see your work any way you want. The sleek and clean design adds a touch of style to your office interior and is VESA-compatible for easy installation
Smart Eco Saving technology achieves power-consumption reductions of up to 10% while still maintaining picture quality. It adjusts the brightness of the screen's black sections while simultaneously adjusting the RGB gain values, so the screen looks just as bright as you remember.
The IPS panel preserves colour vividness and clarity across every inch of the screen. Work comfortably on the productivity-boosting wide display and see accurate tones and shades from 178° all around, with no colour washing
Product Description | Samsung S27R650FDU - SR65 Series - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class F | Energy Consumption per Year | 35 kWh | Power Consumption (On mode) | 24 W | Adaptive-Sync Technology | AMD FreeSync | Features | USB Hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V | Colour | Dark grey/blue | Dimensions (WxDxH) - with stand | 61.23 cm x 23.8 cm x 53.9 cm | Weight | 6.4 kg | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | USB Hub |
Panel Type | IPS |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | MagicBright, game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus |
Dimensions (WxDxH) | 61.23 cm x 23.8 cm x 53.9 cm - with stand |
Weight | 6.4 kg |
Connectivity | |
Interfaces | VGA , DisplayPort 1.2 , HDMI , Audio line-in , Headphones , 2 x USB 3.0 , 2 x USB 2.0 |
Mechanical | |
Tilt Angle | -5/+24 |
Swivel Angle | 90 |
Rotation Angle | -2/+92 |
Height Adjustment | 135 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x HDMI cable , 1 x SuperSpeed USB cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption SDR (On mode) | 24 kWh/1000h |
Power Consumption (Typical) | 24 Watt |
Power Consumption Stand by | 0.4 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.23 cm - depth: 23.8 cm - height: 53.9 cm - weight: 6.4 kg , Without stand - width: 61.23 cm - depth: 7.62 cm - height: 36.16 cm - weight: 4.2 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 68.5 cm |
Shipping Depth | 21.5 cm |
Shipping Height | 43.5 cm |
Shipping Weight | 8.6 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
