The VPL-FH500L's outstanding portfolio of features allows it to offer class-leading projection performance even in the most challenging of environments. Its 7,000-lumen color light output brightness, its zoom and its wide lens shift range, allow it to deliver the clearest image where other projectors would struggle - even in high ambient light.
Once installed, the VPL-FH500L has excellent image capabilities and a long lifespan that delivers low total cost of ownership. Sony's BrightEra technology improves and maintains color purity throughout the life of the system by protecting the LCD panels against harmful ultra violet light. Clever features such as dual auto-switching lamps, and synchronized lamp and filter replacement cycles, reduce maintenance costs and downtime.
Featuring the usual wide range of inputs, an external monitor connection for the presenter's convenience, and advanced projection capabilities such as side-by-side image projection and DICOM medical training, the VPL-FH500L is the projector of choice for venues that demand the high quality in the practical, flexible form.
Product Description | Sony VPL-FH500L - 3LCD projector - no lens - LAN - grey, white | Device Type | 3LCD projector | Colour | Grey, white | Networking | Ethernet, Fast Ethernet | Brightness | 7000 lumens | Brightness (Colour) | 7000 lumens | Contrast Ratio | 2500:1 | Resolution | 1900 x 1200 | Lens | No lens | Bulb type | 2 x | Bulb life cycle | Up to 6000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode | Video Input | RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN | Digital Video Standard | High-Definition Multimedia Interface (HDMI) | Video Modes | 480p, 720p, 1080i, 1080p, 480i | Video Output | RGB, S-Video, composite video, component video | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 53 cm x 54.5 cm x 21.3 cm | Weight | 20 kg |
General | |
Networking | Ethernet |
Data Link Protocol | Ethernet, Fast Ethernet |
Enclosure Colour | Grey, white |
Projector | |
Brightness (Reduced) | 5600 lumens |
Image Size | 102 cm - 1524 cm |
Display Format | 6,912,000 pixels |
Max Sync Rate (V x H) | 93 Hz x 93 kHz |
Bulb type | 2 x |
OSD Languages | Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, Italian, Norwegian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Persian |
Features | 3LCD Technology, BrightEra |
Lens | |
Type | No lens |
Video Input | |
TV System | NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58 |
Analogue video Signal | RGB, S-Video, composite video, component video |
Video Interfaces | VGA, HDMI, composite video, S-Video, DVI |
LAN and Wireless Image Transferring Protocols | Wired LAN |
Video Output | |
Analogue Video Signal | RGB, S-Video, composite video, component video |
Input Device | |
Type | External |
Expansion / Connectivity | |
Expansion Slots | 1 x Expansion Slot |
Interfaces | 1 x composite video input - BNC , 1 x S-video input - 4 pin mini-DIN , 2 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x component video / RGB input - BNC x 5 , 1 x composite video output - BNC , 1 x S-video output - 4 pin mini-DIN , 1 x HDMI input - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x DVI-D input - 24+1 pin digital DVI |
Miscellaneous | |
Included Accessories | Lens hole cover, wireless remote control |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Dimensions & Weight | |
Width | 53 cm |
Depth | 54.5 cm |
Height | 21.3 cm |
Weight | 20 kg |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 35 - 85% |
