Marketing description is not available.
Product Description | Acer X137WH - DLP projector - portable - 3D | Device Type | DLP projector - 720p | 3D Capable | Yes (3D glasses sold separately) | Built-in Devices | Speaker | Microdisplay | DarkChip 3 | Brightness | 3700 lumens | Contrast Ratio | 20000:1 (dynamic) | Resolution | WXGA (1280 x 800) | Native Aspect Ratio | 16:10 | Colour Support | 1.07 billion colours | Bulb type | P-VIP 195 Watt | Bulb life cycle | Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode | Video Input | RGB (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G) | Video Modes | 480p, 720p, 1080i, 1080p, 480i, 576i, 576p | Speakers | Speaker(s) - internal | Power | AC 120/230 V | Power Consumption Operational | 235 Watt | Dimensions (WxDxH) | 31.4 cm x 22.3 cm x 9.3 cm | Weight | 2.5 kg |
General | |
Projector | |
Brightness (Reduced) | 2960 lumens |
Image Size | 75 cm - 762 cm |
Projection Distance | 1.1 m - 10 m |
Throw Ratio | 1.54 - 1.72:1 |
Uniformity | 85 % |
Digital Zoom Factor | 2x |
Resolution | WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized) |
Max Sync Rate (V x H) | 120 Hz x 100 kHz |
Features | 6-segment colour wheel, BrilliantColor, Instant Pack Technology, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology, Quick-Start, ColorBoost 3D Technology, ExtremECO |
Lens | |
Focus Type | Manual |
Lens Aperture | F/2.41-2.53 |
Zoom Type | Manual |
Zoom Factor | 1.1x |
Keystone Correction Direction | Vertical |
Vertical Keystone Correction | -40 / +40 |
Video Input | |
TV System | PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G |
Analogue video Signal | RGB |
Video Interfaces | VGA, HDMI |
Speakers | |
Type | Internal |
Sound Output Mode | Mono |
Output Power / Channel | 3 Watt |
Speakers | 1 x mixed channel |
Expansion / Connectivity | |
Interfaces | 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin mini-USB Type B (management) |
Miscellaneous | |
Included Accessories | Wireless remote control |
Compliant Standards | FCC, ROSTEST |
Power | |
Power Source | AC |
Voltage Required | AC 120/230 V |
Power Consumption Stand by | 0.5 Watt |
Dimensions & Weight | |
Width | 31.4 cm |
Depth | 22.3 cm |
Height | 9.3 cm |
Weight | 2.5 kg |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 0 - 80% |
Sound Emission | 31 dBA |
Sound Emission (Economic Mode) | 28 dBA |
