Asus RT-AC51U Wireless router - 802.11 a/b/g/n/ac Dual Band
£44.80
Delivery:
Key features
  • Next gen 802.11ac wireless, up to 3x faster than 1 x 1 wireless N routers
  • Dual-band connectivity for compatibility and performance
  • No more dead zones with 150% the coverage
  • Add external storage, printers, and other devices to your network
  • Robust control and optimization with ASUSWRT
  • Easy 3-step setup
Product codes
Powered by 5th generation Wi-Fi, the 802.11ac chipset gives the RT-AC51U faster wireless speeds than N technology. At 2.4 GHz, it reaches 300 Mbps, while on the 5 GHz band it blazes to 433 Mbps. The upgraded bandwidth has the higher capacity you need to increase Wi-Fi enjoyment at home. With notebooks, desktops, pads, and smartphones now all Wi-Fi-reliant, it's time to upgrade to the next generation to expand you connectivity now and in the future.
Product Description ASUS RT-AC51U - wireless router - 802.11a/b/g/n/ac - desktop
Device Type Wireless router - 4-port switch (integrated)
Enclosure Type Desktop
WAN Ports Qty 1
Data Link Protocol Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz / 5 GHz
Data Transfer Rate 733 Mbps
Capacity Guest networks: 6
Network / Transport Protocol PPTP, L2TP, IPSec, PPPoE, LPR/LPD, FTP
Remote Management Protocol HTTP
Features Network monitoring, firewall protection, VPN support, Stateful Packet Inspection (SPI), print server, MAC address filtering, IPv6 support, URL filtering, parental control, IP address filtering, download client, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), IPSec passthrough, Samba support, FTP server, Multiple SSID support, static IP mode, ASUS AiDisk, reset button, bandwidth control, 3G/4G USB Dongle Support, dynamic IP mode, Traffic Control, Multicast Proxy support, VPN Server, ASUS AiCloud, ASUSWRT, Guest Zone support, L2TP passthrough
Compliant Standards IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 18.9 cm x 12.9 cm x 3.6 cm
Weight 270 g
System Requirements Linux, Microsoft Windows 2000, Apple MacOS X, Apple MacOS X 10.1, Microsoft Windows Server 2003, Apple MacOS X 10.4, Apple MacOS X 10.6, Microsoft Windows Server 2008, Apple MacOS X 10.5, Android, Microsoft Windows Vista (32/64 bits), Ubuntu, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X Lion 10.7, Windows 8 (32/64 bits), Apple MacOS X 10.8
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus RT-AC51U Wireless...
£44.80
