Mini gender changers from C2G provide the full benefit of a gender changer at a fraction of the space. These low-profile gender changers will quickly and easily convert the gender of any parallel, serial, game/midi or video port. In addition, they can be used to splice together two existing cables. Save yourself the cost and hassle of having to buy a cable for each application; simply change the gender of your existing port and use the very same cable.
Product Description | C2G VGA gender changer | Type | VGA gender changer | Features | Low profile | Connector | HD-15 (VGA) - female | Connector (Second End) | HD-15 (VGA) - female | Compliant Standards | RoHS |
General | |
Connectivity | |
Connector | 15 pin HD D-Sub (HD-15) - female |
Connector (Second End) | 15 pin HD D-Sub (HD-15) - female |
Miscellaneous | |
