Experience 4K ULTRA HD displays with this USB-C to HDMI Adapter which allows you to connect the USB Type-C port of a laptop, Chromebook, tablet or other source device to the HDMI input of a HDTV, projector or other display - making it an ideal solution for showing presentations, pictures or other audio/video content. This adapter supports up to a 4K (3840x2160 at 30Hz) resolution, allowing it to deliver high-quality, ULTRA HD video image to the connected display. The compact design of this adapter makes it a perfect pair for BYOD (Bring Your Own Device) applications in education or corporate environments. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
Product Description | C2G USB 3.1 USB C to HDMI Audio/Video Adapter - USB Type C to HDMI White - external video adapter - white | Device Type | External video adapter | Bus Type | USB 3.1 | Max Resolution | 3840 x 2160 | Interfaces Details | HDMI , USB 3.1 (USB-C) | Enclosure Colour | White | Manufacturer Warranty | 3-year warranty |
General | |
Max Resolution | 3840 x 2160 at 30 Hz |
Features | HDCP |
Miscellaneous | |
Compliant Standards | Plug and Play |
Weight | 32 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
