The USB 2.0 to DVI Adapter provides the capability to extend your viewing options from a laptop or PC. Quickly and easily connect existing equipment to a VGA or DVI-I enabled monitor or projector using your computer's USB 2.0 port. Enjoy extended, mirrored or primary display modes and allow content to be shared across multiple displays which increases productivity while minimizing additional hardware investments. This plug-and-play solution includes an integrated driver that installs quickly and easily for immediate performance.
Once the driver is installed you can use up to six adapters connected simultaneously to a single computer to allow multi-display capability. High definition performance is achieved through resolutions up to 1920 x 1080 pixels and video streaming up to 1080p. With a compact form factor and rugged housing, this unit combines durability with functionality, ensuring optimal performance and results.
Product Description | C2G USB 2.0 to DVI Adapter - external video adapter - grey | Device Type | External video adapter | Bus Type | USB 2.0 | Max Resolution | 2048 x 1152 | Interfaces | DVI-I (dual link) , USB 2.0 | Enclosure Colour | Grey | Manufacturer Warranty | 1-year warranty |
General | |
System Requirements | |
OS Required | Microsoft Windows 2000 SP4, Microsoft Windows XP Professional SP2, Microsoft Windows XP Home Edition SP2, Microsoft Windows Vista (32/64 bits) SP1, Microsoft Windows XP Professional SP3, Microsoft Windows XP Home Edition SP3, Microsoft Windows 7 (32/64 bits) |
Min Processor Type | 1.2 GHz |
Min RAM Size | 512 MB |
Additional Requirements | USB port (compatible with 2.0 specification) |
Miscellaneous | |
Cables Included | 1 x USB cable - 1 m |
Software Included | Drivers & Utilities |
Compliant Standards | RoHS |
Weight | 203 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
