More speed. More bandwidth. More efficient. Next generation DDR4 memory is here.
Overcome one of your greatest server limitations: memory. From networking, cloud computing, and virtualization to HPC, Big Data and more, memory - dependent server applications require increasingly higher densities of memory and higher levels of performance than are attainable on current DDR3 technology. Enter Crucial DDR4 server memory.
Product Description | Crucial - DDR4 - kit - 64 GB: 4 x 16 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - registered | Product Type | Memory kit | Capacity | 64 GB: 4 x 16 GB | Memory Type | DDR4 SDRAM - DIMM 288-pin very low profile | Upgrade Type | Generic | Data Integrity Check | ECC | Speed | 2133 MHz (PC4-17000) | Latency Timings | CL15 | Features | Dual rank, sixteen banks, registered | Voltage | 1.2 V | Manufacturer Warranty | Limited lifetime warranty |
General | |
Memory | |
Type | DRAM memory kit |
Technology | DDR4 SDRAM |
Form Factor | DIMM 288-pin very low profile |
Chips Organization | 2048 x 4 |
Voltage | 1.2 V |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
