Internet from your wall socket: devolo Magic's Powerline technology enables you to enjoy a fast, stable Internet connection in any room. The Magic 2 LAN triple power socket adapter is equipped with three Gigabit LAN ports with a maximum speed of 2400 Mbps. The Starter Kit design gives you a Powerline network with the adapter. But you can also use the Magic 2 LAN triple to expand an existing network. This allows you to dispense with a LAN switch in your home office or living room.
Product Description | devolo Magic 2 LAN triple - Starter Kit - bridge - wall-pluggable | Device Type | Bridge | Enclosure Type | Wall-pluggable | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, HomeGrid | Features | Auto-uplink (auto MDI/MDI-X), reset button | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az | Dimensions (WxDxH) | 7.2 cm x 4.1 cm x 14.3 cm | System Requirements | Microsoft Windows 7 (32/64 bits), Apple OS X 10.9 Mavericks, Android 5.1, Ubuntu 16.04, Apple iOS 10 | Manufacturer Warranty | 3-year warranty |
General | |
Connectivity Technology | Wired |
Encryption Algorithm | 128-bit AES |
Status Indicators | Powerline |
Line Properties | |
Line Coding Format | 64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM |
Expansion / Connectivity | |
Interfaces | 1 x power , LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 |
Power | |
Power Device | Internal power supply |
Power Consumption Operational | 5 Watt |
Miscellaneous | |
Included Accessories | Devolo MAGIC 2 LAN adapter |
Cables Included | 2 x network cable - 2 m |
Software / System Requirements | |
OS Required | Microsoft Windows 7 (32/64 bits), Apple OS X 10.9 Mavericks, Android 5.1, Ubuntu 16.04, Apple iOS 10 |
Dimensions & Weight | |
Width | 7.2 cm |
Depth | 4.1 cm |
Height | 14.3 cm |
Dimensions & Weight (Shipping) | |
Shipping Width | 18.8 cm |
Shipping Depth | 23.1 cm |
Shipping Height | 9.2 cm |
Shipping Weight | 810 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
The following resources are available for the Devolo Magic 2 LAN TRIPLE Starter Kit (3x LAN, Pass-Thru, 2x plugs)
