We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Today's networks have increasing numbers of devices, attached to them, both wired and wireless. As wired devices proliferate, it can be difficult to easily and neatly place networked ports, where you want them. NETGEAR ProSAfe Click switches address this issue with an innovative and thoughtful hardware design, including the flexible Virtually Anywhere Click mounting system. NETGEAR ProSafe web managed Gigabit Ethernet Click switches are uniquely designed with a bracket mounting system for easy installation. Their slim design and internal power supplies enable you to organize wires, secure cables, eliminate bulky power adapters, and improve the overall appearance of wiring closets, training facilities, lab benches, conference rooms, and even home entertainment centers, that require multiple connected devices.
Product Description | NETGEAR Click GSS108EPP - switch - 8 ports - Managed | Device Type | Switch - 8 ports - Managed | Subtype | Gigabit Ethernet | Ports | 4 x 10/100/1000 (PoE+) + 4 x 10/100/1000 | Power Over Ethernet (PoE) | PoE+ | PoE Budget | 47 W | Performance | Bandwidth: 16 Gbps , Latency (10 Mbps): < 77 µs , Latency (100 Mbps): < 8.9 µs , Latency (1000Base-T): < 2.6 µs , Forwarding performance (64-byte packet size): 11.9 Mpps | Capacity | Virtual interfaces (VLANs): 64 , Priority queues: 4 , Layer 2 multicast groups: 128 | MAC Address Table Size | 4K entries | Jumbo Frame Support | 9000 bytes | Routing Protocol | IGMPv2, IGMP, IGMPv3 | Remote Management Protocol | HTTP | Features | Flow control, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, WRR queuing, Broadcast Storm Control, full duplex mode, firmware upgradable, vertical mounting, TFTP support, QoS, horizontal mounting, Jumbo Frames support, fanless, Energy Efficient Ethernet, loop prevention, link aggregation trunking, 192KB packet buffer, Multicast filtering function, CoS, DoS, metal housing, DSCP support, cable test, Virtually Anywhere Mounting, Voice VLAN | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3at, IEEE 802.3az | Power | AC 120/230 V (50 - 60 Hz) 1.4 A | Dimensions (WxDxH) | 30.5 cm x 6.5 cm x 3.5 cm | Weight | 3.2 kg | Localisation | United Kingdom, Europe | Manufacturer Warranty | ProSAFE lifetime warranty |
General | |
Enclosure Type | Desktop, wall-mountable, pole-mountable |
PoE Budget | 47 W |
Status Indicators | Port transmission speed, power, PoE, link/activity |
Expansion / Connectivity | |
Interfaces | 4 x 1000Base-T RJ-45 PoE+ - 124 W , 4 x 1000Base-T RJ-45 |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50 - 60 Hz) |
Electric Current Required | 1.4 A |
Power Consumption Operational | 5 Watt |
Miscellaneous | |
Included Accessories | Cable retaining/pole mounting straps |
MTBF | 1,494,913 hours |
Compliant Standards | CB, UL 60950-1, CAN/CSA C22.2 No. 60950-1-07, KC, EAC, CNS 13438, EN 55024:2010, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, FCC CFR47 Part 15 B Class B, EN 6100-3-3, EN55022:2010 + AC:2011 Class A, VCCI V-4/2012.04, VCCI V-3/2015.04 Class A, ANSI C63.4-2014, ICES-003 issue 6 Class B, AS/NZS CISPR22:2009+A1 Class B, AS/NZS 60950-1:2015, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013 |
Software / System Requirements | |
Software Included | ProSAFE Plus Configuration Utility |
Dimensions & Weight | |
Width | 30.5 cm |
Depth | 6.5 cm |
Height | 3.5 cm |
Weight | 3.2 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days , Technical support - e-mail consulting |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 90% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 95% (non-condensing) |
