The GS516TP Gigabit Smart Switch is a state-of-the-art, high-performance, IEEE-compliant network solution designed for users who require many ports and want the power of gigabit connectivity to eliminate bottlenecks, boost performance, and increase productivity. The front panel of the switch has 16 twisted-paired ports that support nonstop 10/100/1000 networks.
Product Description | NETGEAR GS516TP - switch - 16 ports - Managed - rack-mountable | Device Type | Switch - 16 ports - L3 Lite - Managed | Enclosure Type | Rack-mountable | Subtype | Gigabit Ethernet | Ports | 8 x 10/100/1000 (PoE) + 8 x 10/100/1000 | Power Over Ethernet (PoE) | PoE+ | PoE Budget | 76 W | Performance | Bandwidth: 32 Gbps | Capacity | Static routes: 32 , Layer 2 multicast groups: 1000 , DHCP snooping entries: 1024 | MAC Address Table Size | 8K entries | Jumbo Frame Support | 9KB | Routing Protocol | IGMPv2, IGMP, IGMPv3, MLDv2, MLD | Remote Management Protocol | SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP | Features | Flow control, auto-sensing per device, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, WRR queuing, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, MSTP support, DHCP snooping, TFTP support, ACL support, QoS, MLD snooping, LLDP support, Port Security, DHCP client, Energy Efficient Ethernet, CoS, 8MB packet buffer, 802.1x authentication, ToS, VoIP support, DSCP support, administrator's password | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az | Dimensions (WxDxH) | 32.8 cm x 16.9 cm x 4.3 cm | Weight | 2.213 kg | Localisation | Europe | Manufacturer Warranty | NETGEAR lifetime warranty |
General | |
Enclosure Type | Desktop, rack-mountable |
PoE Budget | 76 W |
Encryption Algorithm | SSL, TLS 1.0 |
Authentication Method | RADIUS, TACACS+ |
Status Indicators | Port transmission speed, power, PoE, link/activity, fan |
Expansion / Connectivity | |
Interfaces | 8 x 1000Base-T RJ-45 PoE , 8 x 1000Base-T RJ-45 |
Power | |
Power Device | Internal power supply |
Power Consumption Operational | 92.1 Watt |
Miscellaneous | |
Rack Mounting Kit | Included |
MTBF | 479,350 hours |
Compliant Standards | CSA, cUL, EN 60950, IEC950, UL 1950, EN55024, EN55022 Class A, CISPR 22, EN50082-1, CCC, FCC Part 15 A, C-Tick Class A, VCCI Class A, TLS v1.0 |
Software / System Requirements | |
Software Included | Drivers & Utilities |
Dimensions & Weight | |
Width | 32.8 cm |
Depth | 16.9 cm |
Height | 4.3 cm |
Weight | 2.213 kg |
Manufacturer Warranty | |
Service & Support | NETGEAR lifetime warranty |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 95% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
