Project bright vibrant presentations in HD effortlessly any time on day. Designed for meeting rooms and classrooms, the W330 boasts sRGB accurate true to life color reproduction, long lamp life and energy-saving features to provide you with a low overall cost of ownership.
This projector is easy to connect to with multiple inputs and a built-in speaker. Perfect for connecting a laptop, PC or Blu-ray player for clear projected images with sound.
Product Description | Optoma W330 - DLP projector - portable - 3D | Device Type | DLP projector - 720p | 3D Capable | Yes (3D glasses sold separately) | Built-in Devices | Speaker | Microdisplay | DarkChip 3 | Brightness | 3000 ANSI lumens | Contrast Ratio | 20000:1 | Resolution | WXGA (1280 x 800) | Native Aspect Ratio | 16:10 | Colour Support | 1.07 billion colours | Bulb type | 195 Watt | Bulb life cycle | Up to 5000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode | Video Input | RGB, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC) | Video Modes | 480p, 720p, 1080i, 1080p, 480i, 576i, 576p | Speakers | Speaker(s) - integrated | Power | AC 120/230 V (50/60 Hz) | Power Consumption Operational | 225 Watt | Dimensions (WxDxH) | 29.8 cm x 23 cm x 9.65 cm | Weight | 2.17 kg |
General | |
Projector | |
Image Size | 68 cm - 804 cm |
Projection Distance | 1 m - 12 m |
Throw Ratio | 1.55 - 1.73:1 |
Uniformity | 75 % |
Resolution | WXGA - WXGA (1280 x 800) |
Max Sync Rate (V x H) | 120 Hz x 91.1 kHz |
Controls & Adjustments | Keystone correction |
OSD Languages | Danish, Hungarian, Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean |
Features | BrilliantColor, 16:9 aspect ratio support, 4:3 aspect ratio support, Auto Power Off, Eco+ technology |
Lens | |
Lens Aperture | F/2.5-2.67 |
Zoom Type | Manual |
Zoom Factor | 1.1x |
Keystone Correction Direction | Vertical |
Vertical Keystone Correction | -40 / +40 |
Video Input | |
TV System | PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC |
Analogue video Signal | RGB, composite video, component video |
Video Interfaces | VGA, HDMI, component video, composite video |
Speakers | |
Type | Integrated |
Sound Output Mode | Mono |
Output Power / Channel | 10 Watt |
Speakers | 1 x mixed channel |
Expansion / Connectivity | |
Interfaces | 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x VGA output - 15 pin D-Sub (DB-15) , 1 x management - mini-USB Type B , 1 x HDMI - 19 pin HDMI Type A |
Miscellaneous | |
Included Accessories | Wireless remote control |
Cables Included | 1 x VGA cable |
Security Features | Security lock slot (cable lock sold separately), password protection, security bar |
Security Slot Type | Kensington security slot |
Compliant Standards | RoHS |
Power | |
Power Source | AC |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Stand by | 0.5 Watt |
Dimensions & Weight | |
Width | 29.8 cm |
Depth | 23 cm |
Height | 9.65 cm |
Weight | 2.17 kg |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 85% (non-condensing) |
Sound Emission (Economic Mode) | 29 dB |
