Connect your VGA Display to a DVI-I source. The DVIVGAMF10PK 10-pack of DVI-I to VGA Adapters offers a cost-effective option when you have multiple DVI-enabled computers to connect to VGA monitors.
At a lower cost per unit, these DVI to VGA adapters convert DVI male connectors to VGA female connectors - a perfect solution for schools, and other organizations to connect DVI-I desktop or laptop computers to VGA monitors or projectors.
The adapters are constructed of high-quality materials to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your devices use a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter (DVI2VGACON).
Product Description | StarTech.com DVI to VGA Cable Adapter - DVI (M) to VGA (F) - 10 Pack - White - Male DVI to Female VGA (DVIVGAMF10PK) - VGA adapter | Type | VGA adapter | Packaged Quantity | 10 (specifications are for single item) | Features | Molded, thumbscrews | Connector | HD-15 (VGA) - female | Connector (Second End) | DVI-I - male | Compliant Standards | RoHS | Colour | Beige | Manufacturer Warranty | Limited lifetime warranty |
General | |
Plated Connector | Nickel |
Colour | Beige |
Connectivity | |
Connector | 15 pin HD D-Sub (HD-15) - female |
Connector (Second End) | 24+5 pin combined DVI - male |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
