The Archer VR600 unlocks the full potential of your Internet connection by providing combined dual band Wi-Fi speeds, eliminating lag and buffering from your online experience. Dedicated Wi-Fi networks support more devices and reduce wireless interference to create stable connections.
Product Description | TP-Link Archer VR600 - v2 - wireless router - DSL modem - Wi-Fi 5 - desktop | Device Type | Wireless router - DSL modem - 4-port switch (integrated) | Enclosure Type | Desktop | Digital Signaling Protocol | ADSL, ADSL2, ADSL2+, VDSL2 | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz / 5 GHz | Data Transfer Rate | 1600 Mbps | Capacity | IPSec VPN tunnels: 10 , Permanent virtual circuits (PVC): 8 | Network / Transport Protocol | TCP/IP, PPTP, IPSec, PPPoE, PPPoA, IPoA, IPoE, DHCP, DNS, DDNS | Routing Protocol | IGMPv2, IGMP, static IP routing, IGMPv3 | Remote Management Protocol | SNMP 1, SNMP 2c, HTTP, HTTPS, CLI, TR-069 | Features | Firewall protection, DMZ port, NAT support, VPN support, DoS attack prevention, ALG support, dynamic DNS server, manageable, print server, IPv6 support, Wireless Distribution System (WDS) support, parental control, firmware upgradable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, Samba support, FTP server, port forwarding, reset button, IPv4 support, port triggering, DHCP relay, Traffic Control, IP-MAC binding, DNS relay, DHCP client, SYN Flooding, Ping of Death, SFTP server | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac | Dimensions (WxDxH) | 21.6 cm x 16.4 cm x 3.68 cm | System Requirements | UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8.1 / 10, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8 |
General | |
Device Type | Wireless router - 4-port switch (integrated) |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, RoHS, RCM |
Line Properties | |
Framing Format | ANSI T1.413i2 |
Communications | |
Type | DSL modem |
Protocols & Specifications | ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.993.2, ITU G.998.4, ITU G.993.5 |
Expansion / Connectivity | |
Interfaces | LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , Phone line: 1 x VDSL2 / ADSL2+ - RJ-11 , Antenna: 3 x RP-SMA |
Aerial | |
Aerial | External detachable |
Antenna Qty | 3 |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Included Accessories | ADSL splitter |
Cables Included | 1 x network cable , 1 x phone cable |
Software / System Requirements | |
OS Required | UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8.1 / 10, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8 |
Dimensions & Weight | |
Width | 21.6 cm |
Depth | 16.4 cm |
Height | 3.68 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
