Devolo Mesh WiFi 2 Whole Home Kit
Key features
  • Strong mesh network
  • Optimum mesh tri-band
  • Strong signal over long distances
  • Perfectly coordinated
  • Flexible connection options
  • Maximum security
Product codes
Documents
chevron icon
chevron icon
devolo Mesh WiFi: All devolo units form a coherent network that not only amplifies your router WiFi, but also replaces it optimally – for seamless reception.
  • High-performance Wi-Fi: Up to 100 end devices can be supplied across rooms at maximum speed, with the choice of 2.4 or 5 GHz Wi-Fi.
  • Optimum mesh tri-band: The combination of Wi-Fi ac with Powerline technology enables the best distribution of Internet throughout the home – for a stable connection.
  • Flexible: Additional Gigabit LAN ports and power outlets provide more connection options for your end devices.
  • Compatible with all devolo Magic series adapters and can be expanded at any time. (devolo dLAN series adapters are not supported.)
  • 3-year manufacturer's warranty.
Mesh Wi-Fi in its best form
Surf without gaps! Unlike conventional starter kits for home networking, the devolo Mesh WiFi set consists exclusively of WiFi units that replace your existing router WiFi with a pure mesh network. Up to 100 terminal devices can be supplied with WiFi at maximum gigabit speeds in a cohesive network. Eradicate wireless gaps and experience the best network coverage!
The fastest tri-band of its class
WiFi ac meets Powerline: Perfect Wi-Fi is transmitted to all end devices over two frequencies (2.4 and 5 GHz) with secure encryption. The devolo units distribute the Internet signal via power line throughout the home, ensuring a lightning-fast, stable network!
Adapts to your home!
The devolo Mesh WiFi network can be flexibly expanded at any time – you can easily connect additional devolo units to the existing network at the touch of a button. In the devolo mesh network, all settings for data security and performance optimisation are automatically synchronised.
A tip for even better mesh performance
For unimpaired performance, please switch off the router Wi-Fi. The devolo units then form a pure devolo mesh network. By using this trick, you enable the full range of functions of the perfectly co-ordinated devolo units and provide a performance boost – particularly in the case of older routers. Now your end devices will no longer be throttled by obsolete router Wi-Fi.
A real team player
devolo Mesh WiFi adapters are compatible with all Wi-Fi routers, Wi-Fi-capable devices and, of course, devolo Magic adapters. dLAN® Powerline adapters and other HomePlug AV products, including the devolo Outdoor WiFi Powerline adapters, are not supported.
chevron icon
Product Description devolo Mesh Wifi 2 - Multiroom Kit - powerline adapter kit - Wi-Fi 5 - Wi-Fi 5 - wall-pluggable
Device Type Powerline adapter kit
Enclosure Type Wall-pluggable
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, HomeGrid
Frequency Band 2.4 GHz / 5 GHz
Data Transfer Rate 2400 Mbps
Features Auto-uplink (auto MDI/MDI-X), IPv6 support, parental control, Mesh networking, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), integrated power socket, reset button, IPv4 support, SISO technology, Airtime Fairness, 2x2 MIMO technology
Compliant Standards IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.3az, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v
Power AC 230V (50 Hz)
Dimensions (WxDxH) 7.6 cm x 4 cm x 15.2 cm
Localisation United Kingdom
chevron icon
Resources
The following resources are available for the Devolo Mesh WiFi 2 Whole Home Kit
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
