iiyama MD BRPCV01/VESA Mount Bracket SFF - White
Product codes
chevron icon
chevron icon
MD BRPCV01 is a high quality bracket that allows a Mini PC or Thin Client to be mounted to the iiyama Height Adjustable stand. This solution is compatible with almost all ThinClient/ZeroClient PC's and with basically all iiyama 19'' to 24'' height adjustable monitors.
chevron icon
Product Description Iiyama thin client to monitor mounting bracket
Product Type Thin client to monitor mounting bracket
Colour White
Designed For ProLite B1980SD-B1, B1980SD-W1, B2280HS-1, B2280HS-B1DP, B2280WSD-1, B2480HS, B2480HS-2, B2480HS-W1, B2481HS-1, XB2380HS, XB2485WSU, XB2485WSU-1, XB2485WSU-2
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
