We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Please Note: This is only the Dual Monitor Arm, not the full Workstation. This needs to be purchased with KW55792WW - Quicklinx BWGP
Take productivity to a professional level by adding a dual monitor arm to your SmartFit Sit/Stand Workstation. Studies have shown using two monitors can have a dramatic effect on workflow. With dual monitors on your workstation, not only are you getting the ergonomic and health benefits of standing while you work, youre also getting a lot more work done. Our patented SmartFit System lets you find your personal comfort color to set the monitors at the ideal viewing height, plus the arm installs quickly to your Sit/Stand workstation and is VESA-compatible for monitor screens up to 24 inches.
Product Description | Kensington mounting component - for 2 monitors - black | Product Type | Mounting component | Mounting Components | Dual arm | Recommended Use | 2 monitors | Recommended Display Size | Up to 24" | VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm | Max Load Weight | 10.2 kg | Colour | Black | Manufacturer Warranty | 2-year warranty |
General | |
Colour | Black |
AV Furniture | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
