Boost the WiFi coverage in your home by adding the NETGEAR EX3800 AC750 Simultaneous Dual-Band WiFi Booster/Range Extender. With speeds up to 750Mbps and an extra Ethernet port, you can connect to speed for gaming and streaming via WiFi or a wired connection. Convenient wall-plug design lets you discreetly place the range extender where you need it, while the new pass-thru design lets you keep access to your outlet.
Key Features
Product Description | NETGEAR AC750 WiFi Range Extender EX3800 - Wi-Fi range extender - Wi-Fi 5 | Device Type | Wi-Fi range extender | Form Factor | External | Localisation | United Kingdom | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz, 5 GHz | Dimensions (WxDxH) | 6.4 cm x 4.45 cm x 11.4 cm | Weight | 192 g | Manufacturer Warranty | 2-year warranty |
General | |
Width | 6.4 cm |
Depth | 4.45 cm |
Height | 11.4 cm |
Weight | 192 g |
Networking | |
Connectivity Technology | Wireless |
Data Transfer Rate | 750 Mbps |
Status Indicators | Power, status |
Features | Auto-sensing per device, Wi-Fi Protected Setup (WPS), Push ‘N’ Connect button, FastLane Technology |
Encryption Algorithm | WPA-PSK, WPA2-PSK, WEP |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac |
Aerial | |
Antenna | External integrated |
Antenna Qty | 2 |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T - RJ-45 |
Power | |
Power Device | Internal power supply |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
