Bring your living room to life
Tap a custom activity such as "Watch TV" and the right devices power on and automatically switch to the right settings.
Easy-to-use design
Every aspect is designed to make commanding your entertainment easy.
Power at the ready
Keep Harmony 950 charged and ready with the convenient charging station.
The replaceable battery has 20% greater capacity than previous generation Harmony remotes.
Get started in minutes
Stop using trial-and-error to find remote codes. Add devices simply by entering the device model numbers and brands.
What's in the box?
Product Description | Logitech Harmony 950 universal remote control | Device Type | Universal remote control | Dimensions (WxDxH) | 5.4 cm x 3.9 cm x 19.2 cm | Weight | 163.8 g | Connectivity Technology | Infrared | Supported Device Qty | 270000 | Input Device | Touch screen | Display | LCD 2.4" | Battery | Rechargeable | Manufacturer Warranty | 2-year warranty |
General | |
Width | 5.4 cm |
Depth | 3.9 cm |
Height | 19.2 cm |
Weight | 163.8 g |
Features | Sleep timer, back-lit buttons, vibration feedback |
Display | |
Colour Display | Yes |
Connections | |
Connector Type | 1 x USB (4 PIN USB Type A) |
System Requirements | |
Operating System | MS Windows 7, Windows 8, Apple Mac OS X 10.7 or later, Windows 10 |
Miscellaneous | |
Included Accessories | AC power adaptor, USB cable, remote control charging stand |
Power | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
